Philips 32" LCD tv display resolution more than 1024*768
kpit
Pune
Hi all,
I would need your help..
I have connected my computer to my 32" LCD TV. according to the user manual of TV, it supports the computer display resolutions
1024*768 at 60, 72, 75, 85 Hz. and 1280*1024 at 60 Hz.
I recently bought XFX ATI 4650 graphic card.
After installing the card and its related drivers, I tried to change the display resolution to 1280*1024 at 60 Hz, 1024*768 at 60 Hz. But the display is blurred and not so clear. if I configure the resolution at 1024*768 at 75 Hz the display is very clear and sharp.
Even before installing Graphic card also I could see display clearer and sharper only for resolution 1024*768 at 75 Hz.
So I would like to understand if I need to change any other settings also in order to get fine picture quality at 60 Hz..
My PC details:
Pentium 4 CPU
Asus P5GL-MX 800MHz FSB Intel 915GL Chipset Dual Channel DDR 400 Socket 775/T micro ATX Motherboard with LAN, SATA, PCI-Express 16X, On-Board Video, 6 Channel Audio, USB 2.0
buddy.. any graphics card will be able to display the max resoultion that tv can support...
if the tv does not support more than 1024 x 768 even the best of the cards cant help..
also check what the max it can support is guess it should be 60hz however as it is philips it might be 75hz not sure.. but changing the card wont help..
its the only way to stick wid it..
or do one thing.. if you have an hdmi port on the graphics card connect that and if the tv supports 720p/1080p you will get proper resolution..
that is the only way..
