Phono for my Project Genie
navinmra
Hi FMs -
I live in Bangalore. Need your recommendation on a phono that I can go out and buy for my TT. I used to have a Denon 2106 that had a phono stage and my upgraded 2113 does not have one hence the need for a separate phono.
There are many phonostages out there in different price ranges. The most common ones are from NAD and Cambridge audio (in the budget category). If you have a flair for DIY, then the CNC phonostage is the way to go.
I have heard this phono stage from Music Hall - PA 1.2. Sounds very good for the low price. And will handle both MM and MC.
Hi FMs -
Since you are in Bangalore check out the Trigon Vanguard at The Listening Room. Hand made in Germany. No China crap. I use it myself and it's very good value for money.
Two reviews:
http://www.trigon-audio.de/fileadmin/pdf/presse/usa/stereophile.pdf
http://www.trigon-audio.de/fileadmin/pdf/presse/england/hifiplus_(uk_2003).pdf
The prices mentioned in the reviews are much higher than the price here in India
