Pioneer Cartridge - PC-330 Mark II
sudhirbhosale
Hyderabad / Mumbai
Hi friends
I got Pioneer Cartridge - PC-330 Mark II, but with the different needle fitted with it causing little misalignment.
I am thinking to buy proper stylus, but before that I want to know how good or reputed this cartridge is? If we consider AT95 as base, then this would be sounding same, less or better?
Is it worth spending to buy cartridge? (if going to get good sound). I am using entry level Turntable but may upgrade.
if you have the original stylus - that might be better than the AT as it has some very nice features.
But if you are planning to buy a generic replacement stylus - there may be not much improvement, and the cost is about the same as an AT 95E cart, which may even end up sounding better!
only reason to stick to the cart is if you want to keep it all original all pioneer, and cost is not a big issue
