Koushik.Bag
I am planning to buy a turntable and my budget is 50k. Can you suggest me with the best warm sounding TT
Was enquiring about it as the issues which you mentioned, are easily fixable. And unknown to many, the SL3200, even with its budget turntable tag and is plastic plinth, is one of the most accurate and lively sounding turntables out there (especially when compared to its Technics siblings). It is usually quite sort after and a lot of turntable aficionados usually silently or secretly keep one of these in their collections.Still with me actually - And quite playable. But do not need it now. In case anyone is interested...
Thanks @reubensm - that was quite some good information.Was enquiring about it as the issues which you mentioned, are easily fixable. And unknown to many, the SL3200, even with its budget turntable tag and is plastic plinth, is one of the most accurate and lively sounding turntables out there (especially when compared to its Technics siblings). It is usually quite sort after and a lot of turntable aficionados usually silently or secretly keep one of these in their collections.
Mechanically, servicing this turntable is also very easy, and the tonearm is very accurate and tracks well with most cartridges. The Stop button tends to get stuck and the speed selector becomes unreliable over time but these are easily serviceable. That's why I have retained it despite having other turntables on my rack.
On another note, the dust cover hinges are made of plastic which tends to get brittle over time and break (this is a turntable that was manufactured in 1978 so that's a long time ago). Replacement spares are very expensive online, however you have 2 options - (1) get them fabricated locally, (2) play the turntable without the dustcover.
Another issue which is common in all Technics direct drive turntables (with the exception of the SL1200 series), is that over a period of time, the transformer starts humming, which in turn is picked up by the cartridge as rumble. This can be minimised by using dampening on the transformer mount.
Important: The controls of the SL3200 are left outside the dustcover and hence, please ensure that after a round of LP listening, let the turntable cool down for about 20 minutes and then cover it well. The pitch controls and speed selector switch tend to fail because of this. The speed selector switch is a unique one and getting a spare part is extremely difficult. However it can be stripped and cleaned which will get it back to normal functionality.
@Beast_of_burden Very informative and very useful lessons I learnt from you.I experimented with the extra 4gm headshell weight but this made the sound dull. There is also an extra weight at the tonearm end which is evidently enough . It sounds much better without the extra headshell mass.
I have the DL103R on the stock Pioneer headshell. I have a Technics headshell but I don't think it makes a noticeable difference. If at all I wish to try another headshell, it will be one with an Azimuth adjustment. Even Soundsmith advocates tonearms with adjustable azimuth as the needles are often misalinged inside the cart. The DL103R is a tall cartridge, I raised the tonearm by about 1.5mm from 0 as I read in the forms the DL103R being a low compliance cart likes the tonearm angled down ever so slightly. The only impact I could perceive was the pops and tics got attenuated a bit. I have some really old Carnatic LPs from way back and these are recorded and pressed beautifully but lots of pops due to age, it helped with the older records.@Beast_of_burden Very informative and very useful lessons I learnt from you.
What headshell you are using with DL-103R?
Thank you very much
