I have two options to place my Elac s10 subwoofer(planning to buy). Due to limitations of room space, only two options of placement is possible.
1. In the corner (so wall on two sides) of the room with tv stand on one side and tower speaker in front. (With two inch gap on all sides) .
2. Placing the sub woofer inside a dedicated space among the table. So two sides and top will be table wall( 3 inch gap) , front open and wall at back with a 6 inch gap . It's on the floor, not table. The table can be designed to include it.
So which would be the better option for the best results?
