planning to buy denon 1612/ pma 710
rajaashwani
hyderabad
hello all!
two queries i have:-
1. which one is better.. sound quality wise:- avr 1612 or pma 710?
2. which are the best compatible speakers with :-
-avr 1612, and
-pma 710
(my budget is rs. 55000/-, ampli and speakers inclusive).
.....awaiting your responses eagerly!!
One s meant for music (PMA 710) and the other is meant for movies and less of music (The AVR 1912)...wat r yr requirements?? Better than the 710 is Marantz 6003/NAD 326BEE
Simple! you want two channel setup , go for pma 710 or you want HT setup 5.1 or .71 then go for AVR.
Hello friends,
I have decided to go for the DENON AVR 1612.
My room size is - 17 ft x 12ft
Listening preference - 70% Music ; 30% Movies
Kindly suggest :
1. Floor Speakers - (Make and Price)
2. Woofer/Sub - (Make and Price)
3. Satellite speakers - (Make and Price)
4. Centre speaker
My Budget is @1,00,000/- for the whole package (5.1)
P.S. - I have the cabling for speakers already in place.
Thanks for your inputs.
Manoj
Hello friends,
Kindly suggest :
4. Centre speaker
Manoj
Dear Manoj,
It would be nice if you could start your own thread instead of hijaking other threads. This thread has a totally different topic of discussion.
It will help people to guide you better.
Just my 2 cents :p
Ayush
@rajaashwani Can you please clarify which AVR you are looking at since I remember you asking me about 1912. And now you have mentioned 1612.
BTW 1912 is a 7.1 AVR while 1612 is a 5.1 AVR.
Also can you specify your interest. i.e stereo setup or 5.1 or 7.1 setup.
though in your budget you wont get a decent 7.1
Ayush
