Buy used speakers.Hi just ordered a Denon 3800h want to hook up with Speakers but confused so much please help it out open for everything speaker budget under 50k subwoofer under 30k
50 k would be very less for 5.1 aetup, if you still want to strict to that budeget then look into Taga harmony , Mission LX1, LX2 .., ELAC debut B5 ..etc.Hi just ordered a Denon 3800h want to hook up with Speakers but confused so much please help it out open for everything speaker budget under 50k subwoofer under 30k
If you are open to used speakers, seen a couple of ads over Market Place over facebook and even olx. Some of them are really good speakers which can provide you a decent performance and last you easily for the next 3-5 years depending on how you use and maintain them.
Yes i see need to start with basics and gradually buy everything else50 k would be very less for 5.1 aetup, if you still want to strict to that budeget then look into Taga harmony , Mission LX1, LX2 .., ELAC debut B5 ..etc.
within 30 k u may get 10" Sub, if you want real kick in in the BASS then u need 12" Sub.
Or start with 2.0 setup with powerful speakers then gradually upgrade to 5.1 when u get budget.
consider speakers like : Wharfedale ,Monitor Audio, Dali ..etc.
I can't find use ones anywhereIf you are open to used speakers, seen a couple of ads over Market Place over facebook and even olx. Some of them are really good speakers which can provide you a decent performance and last you easily for the next 3-5 years depending on how you use and maintain them.
buy a pair of elac b 6.2 Or klipsch R series bookshelves. Tgen graduaaly you can buybtgecremaing.I can't find use ones anywhere
THANK YOUGive me some time will DM you a few.
Is Taga 607 good as it is an entry levelAnd check taga 607. 5.0 Is appx between 40 to 50k. Sub you can add later.
