Please suggest 55" LED - Urgent!!!
vij
hyderabad
Hi guys
Looking for advice in buying the best 55" LED under 1.20 lacs.
The price we got for LG 55LB6500 is 1.17lac with sound bar free. Is this a good price?
There's also LG 55LB750T - would you consider this better than LG 55LB6500 ?
From the specs, the only difference I see are the slightly better native speakers (which isnt a factor) .
Any other TV I should consider.
I own the 64 F8500 already and love it - but this is for my father and he seems to appreciate a bright LED type picture with lots of contrast.
Please advice.
Hi guys
Please advice.
LG 55LB750T has 200 Hz native refresh rate and 800Hz MCI and it has local dimming as per the spec sheet. 55LB6500 has 100Hz native refresh rate and 500Hz MCI.
These IPS panels can go bright, but contrast ??? It lacks in black level and hence contrast ratio is nothing to talk about. Coming from 8500 Plasma, you should very well aware of the need of deep blacks for a striking contrast ratio.
