Please suggest budget speaker stands
Ispahir
New Delhi
Hello Folks
I am in need for some help again. I am looking for speaker stands for my Q Acoustics Concept 20 bookshelves. Budget is not much, maybe under 10k. If there is any wall mounting bracket available, I can go for it too. I am open for used stands too.
Thank You
Hello Folks
Thank You
For wall mounting you need to buy f brackets and glass slab. You can have it custom built with measurements as well. This will be very cheap. And speaker stand check Jenefas as it will cost less
Not sure. I have seen few of their models in amazon. Similar models with other brands also available in amazon for 3-5k. If you are ok with mounting then glass top will be cheap and best.
Hello Folks
Thank You
Under 10K, Sound foundations opal will be good for your speaker size. Next model [Nexus] is around 11K.
Hello Folks
Thank You
A portable TV stand can hold the speakers firmly, also has horozontal swivel, vertical tilt and easy on the pocket.. Shouldn't cost more than Rs 1,000 for a pair of stands..
