For quiet some time I have been toying with the idea of adding a power Amplifier in the range of 150 200 W RMS to improve the dynamic response of my stereo system.
My existing set up:
1)Source Files: FLAC, WAV,320 Kbps Mp3 on Hard disc
2) Player : Marantz NA -7004 network player- USB connection to HDD
3)Amplifier: Arcam A 28 Stereo Amp - Continuous power output (20Hz20kHz at 0.5% THD), per channel 8 Ohms 75 W
5)Speakers: Tannoy Revolution DC 6T SE Towers
Recommended Amp Power: 20 - 175 ( Watts RMS)
Continuous Power handling : 87 W RMS
Peak Power Handling : 350 Watts
Sensitivity: 89 dB
Nominal Impedance: 8 Ohms
6) Cables: IC - Monster M 8501 , Speaker Cables : 12 Gauge - MX
My Listening distance is about 10 to 12 feet at low volumes, room size 22 FeetX18 Feet.
I can source a Power Amp from USA and am considering amps with in a budget of $300 to $500. ( Open to : Used/ New/Vintage )
After going through the available options on e bay, got thoroughly confused and need some expert advise.
The only firm shortlist I could make is on Emotiva XPA 200 at $400. Partly the deciding factor is the 220 V suitability. Other options in the used market : i) Adcom GFA 555 ,ii) NAD 2600A . Liked Carver but they do not seem to be having 220 V Option.
My queries/ Doubts:
a) Is my upgrade path correct or will adding any of the above amps degrade the SQ. I am not unhappy with my existing set up but the upgrade bug has caught me.
b) Alternatively can you suggest a Power Amp in the $300-$500 range? Even in India if available.
c) Also any pointers on what pitfalls to watch for. ( other then the pitfall of buying used gear) I will not be able to audition the Amps but I am assuming that the power Amps will not add any color to the SQ.
My existing set up:
Sensitivity: 89 dB
My queries/ Doubts:
