I have a Naim XS-2 for sale...very good bass control and should go quite well with the Tannoys..
Thanks for the offer - I feel at 100 W the Niam is only a small step up over my Arcam which is capable of 75W.
Yes I did try different speaker positions ( In a limited way -with in space constraints). Will also try with a different IC I have ( a Profigold PROA4201 IC).
The speakers have 6" Woofers and as per specs go down only upto 34 Hz
You will be hard pressed to find music recorded below 34 Hz or even 40 Hz!
What you are hearing is probably what the music should sound like.
Do give your system more time and you will probably get to like it. Try to hear unamplified music. Get someone to play the guitar, the tabla, the drums and see if the bass goes as low as your setup.
Having the speakers closer to the back wall will give more bass.
Try to borrow better ICs than the Profligold and see if it makes any difference.
I did not pursue the sub woofer as I do not want a booming sound and want the low frequencies to be well merged and be part of the music. Not sure if I can achieve this with a separate Sub.
