Pls suggest a stepdown transformer for Denon x2100w
srijith
Thane
Hi, i recently purchased a denon avr x2100w. This was from US..so iam confused as to which stepdown transformer to use.. should i use a 500watt or 750watt transformer and what all should i need to look before going ahead with the buy. Please suggest.
Sri
Sri
Hello Srijith,
Denon 2100W is rated for 500W.
Considering that the transformer has an efficiency of 85%, you will need a 600W transformer.
So the specifications would be:
Primary: 230Vac/ 50Hz (You will connect this to AC mains in India)
Secondary: 110Vac/ 50Hz/ 600Wrms (You will connect this to Denon AVR)
If you get a choice, get the one with CRGO core instead of CRNGO.
Do let me know if you still have doubts.
Ravindra.
Hello Srijith,
Ravindra.
Hi Ravindra,Thank you for the suggestion, please recommend me a transformer which i can buy
I did, in post # 2.
I think you want me to point you to an online link, is it?
I have never purchased one online. I always get one made from my local transformer shop.
The closest I can suggest is Argo Transformers:
Address: No. 187, Opposite Mirvana Cinema, Dr. Bhadkamkar Marg, Grant Road East, Mumbai, Maharashtra 400007
Phone: 022 2308 0793
This company is good and reputed.
I hope that this helps.
Ravindra.
I did, in post # 2.
Ravindra.
Hi Ravindra, this is perfect for me..will go and visit their shop..Many thanks for solving my confusion
