Recommended step down transformer
  • 2 output socket (accepts grounded U.S. & Ungrounded U.S.) - converts automatically. Just Plug in anywhere in the world
  • It will convert converter frequency along with the voltage for items up to 200W. Making This device perfect for trimmers, shavers & clippers.
  • 4x 5V USB slot - for use with iPhone, iPad, iPod, cellphone chargers & etc.
  • NOTE: This converter is not designed for use with hair dryers, power tools, heaters, and other high power products. If used continuously do not Exceed 200W
  • Travel ready: it includes 3 plugs that's cover most of the world. Type C - Europe & Asia, Type g- UK, UAE, Hong Kong, Type I - Australia & China. It also includes a travel pouch so its ready to go.
Just wondering if it is a SMPS type of convertor which can introduce noise …
Over-specify a step-down transformer by 4 ( to 10 ) times. Find a large used commercial unit.
If you can't find one, Shilchar can make what ever you need.
Audio equipment sounds better with 120 VAC floating internally, rather than 230 VAC fields internally interacting.
Jeff
Jeff
Still no one can solve the mismatch of frequency. Most of the world are on 50Hz.
