pmc speakers reviews anyone who have heard them
bhash
india mumbai
have bought dyna audio b&w dali still did not get tht sound tht want how is pmc vs these brands any one whos heard it plz kindly guide
I had Pmc 2 and like Mr. Ilar said that it goes deep, deep and very detailed. Go excellent with tube amps.
Stereo HiFi Rig: Cambridge Audio Cxn v2 + Cyrus6 / Elekit tu 8730 300b + ASI Live line power cable + ASI Live line Reference IC + Townsend Isolda speaker cables + Linn Keilidh speakers
What sound are you looking for? While B&W's are known to be bright, Dali is considered to be on the warm side and you didn't like either? Which models did you listen to?
Dyna audio - Brutally accurate
I presume you mean Dynaudio.
That depends on the range.
Their Studio Monitors are very transparant while their home audio lines have a little different signatures depending on the model.
All their models though are power hungry.
Trouble is their drivers specifically the mid bass drivers. They have some weird diffraction artifacts. So unless the studio line is using different drivers, they will also have the same dips.
What amplification and room size do you have ?
Which models of Dynaudio/ B&W and Dali have you heard ?
What kind of music do you hear and what is your source ?
What is Your Budget
Without these its not easy to give you any reasonable answer which can be acted on by you.
Almost like asking I have driven a MG and a Hyundai and is Kia better :D
