Polk atrium or owm for Atmos height speakers
Atrium is outdoor range. For home, owm3 adequate. If inceiling possible then look at rc60 or v60 as well
so is there an issue in using these outdoor range speakers model for atmos?, I believe they come with wallmount brackets with which they can be ceiling mounted...
can be used but cost higher. OWM3 can be ceiling mounted with a separate mount easily. Search the forum for options.
I was in the same dilemma few months ago and have installed OWM 3 as Atmos speakers and i am quite happy with their sound quality, even my surrounds are OWM 3.
