VSG12777
Hi everyone
I just picked up a Denon 2113 AVR and a Polk Audio PSW 110 powered subwoofer over the weekend. The AVR was to replace my old Yamaha RX-V459 receiver which was non-HDMI. I have the Yamaha NS-8390 3-way tower speakers and the NS-P60 centre and surround package.
I didn't have a very big budget for the subwoofer so I chose this Polk Audio model since I was offered the same for 13.5k at ProFX, 15k being the MRP. I previously used a Sony 100W powered subwoofer from my parents' place which was part of a HTIB system there, that I purchased back in 2003. Nice punchy sub.
Ok coming to the issue at hand, I find that with this Polk PSW 110, I have to push the volume beyond 50% (almost 65-70%) to get proper punch from DTS blu-ray music videos, or movies. I have set the crossover at 80Hz as mentioned in the subwoofer manual and have set the same in the Denon 2113's subwoofer menu as well.
"Phase" at the rear of the sub has been set to 180. The other setting is zero (0). The subwoofer out from the Denon has been connected to the sub using a single coaxial cable that I had purchased some time back from MX.
My question is, is this due to the design of the subwoofer? I used to get very good punch from the 8 inch Sony subwoofer of 2003, at even 40% volume. This one, is supposed to be 200 watts and has a 10 inch driver - so I expected much more.
Up to 50% level on the sub, the bass is very low. You almost can't feel the extra bass from the sub in most scenes/music videos. My tower speakers already produce reasonably good bass. However I wanted to complete the .1 in the 5.1 setup by adding the subwoofer.
This issue has been worrying me.
(1) Is this a design issue? Perhaps, the increase from 0 to 50% is very gradual, and from 50-100% is much more as per the design?
(2) Should I consider upgrading to the next model PSW 125 (300 watts, 12 inch driver), for 18k? ProFX is willing to take this and give me the 125 for 4.5k extra.
(3) I read on a few reviews on the internet, that this subwoofer requires a solid break-in period. How many hours should it be? 20 hrs? 50 hrs?
In any case I have time till about 20th of March, when ProFX would receive fresh stocks of the PSW 125. So I need to make up my mind by then, regarding the upgrade.
I did go through a few threads and found some of you owning the PSW 110 and 125 models. So please do share your thoughts.
I have increased the subwoofer level in the receiver's menu to full (+12 dB), and in speaker level settings, the subwoofer out is at +6 dB. This can also be increased to +12 dB.
Warm regards,
Venkat
Warm regards,
Venkat
