I live in Mumbai. Options to buy good speakers in a small budget are limited. I have a Pioneer VSX 523k receiver.
After searching in my budget (below Rs. 22500), I have narrowed it down to these four
1. Polk Audio RTi A3: 89db, 6.5 inch 1 woofer/mid
2. Polk Audio TSi200: 5.25inch 2 mid/bass drivers. Find that to be a huge plus!
3. Q Acoustics 3020i: 1 single 5.25inch mid/bass drivers
4. Sony SSCS5: 1 single 5.1inch mid/bass drivers
I have not been able to and unfortunately will not be able to test/listen to any of them. My room is 15 x 15, so medium sized room. Since I cannot listen to them (based my selection from reviews), I would like to get suggestions. I am leaning towards the Polk Audio's in general (available on PayTmMall for Rs 22-23K, after cash back)
The small 5/5.25inch driver on the Q Acoustics and Sony SSCS5 makes me think they will be a little less power, low-end wise. While I was inclined towards the Sony SSCS5 due to its price (below Rs. 12K), the 6ohm rating and 87db sensitivity are making me think my receiver will find it difficult to make them loud.
The dual 5.25inch driver on TSi200 and the single bigger 6.5inch driver on the Polk Audio, makes me lean towards them a bit more.
Two questions
Between the 4 speakers (not keeping in mind the price) which one would our forum members recommend?
Between the 2 Polk Audio speakers which one would our forum members recommend?
Thanks,
Chiraag
Two questions
Thanks,
Chiraag
