Power Amplifier
Kowju's
Hyderabad
Hi frineds..
I have two Pioneer 1212D4 (500 RMS) Passive subwoofers! If I want to connect them to Denon X2700H AVR.. what should I need to drive them. suggest the best budget external amplifier?
Hi frineds..
A crown power amp is all you need. Connect it to the sub out on your receiver.
MaSh
the above are drivers only or do you have them installed in a cabinet ?
Thanks for your response! Yes bro.. installed in the cabinet!
Check out the B&W SA 1000 subwoofer amp. It drives upto 2 subwoofers of the same type together. I use it .
Cheers!
Anand
Thanks for your response! it's out of my budget brother.
MaSh
Thanks for your response! Yes, it works. but am looking for an inexpensive option.
I am using a Crown xls 2502 to drive my 15 inch Velodyne sub and it works to my liking.
Check this
4D Furnishers HSWA-300 300 Watts RMS Wired Single SubWoofer Amplifier Black Color (New Version) https://amzn.eu/d/4XwrALv
Thanks for your response! checked that friend. but is that an ok product?
Can I use this streo amp to power them?
can I use this amp to power them?
