As I decided to take the jump in HiFi audio world with a limited budget, prognosis looked bleak for me finding something good in that budget and which fills my requirements too. This was concurred by few forum members too. But as of now I have options and now need your help to decide what to go for.
My usage is still as below:
While the Norge is most basic one and well under the budget, it has no Pre Out so to pass on the signal to another amp, I would have to run parallel RCAs which I'm suspecting, is going to add noise in the system.
Sansui has a Pre Out, is within budget but "vintage" of the 3 (AFAIK).
Onkyo has everything imaginable and then some, but it barely fits my budget and leaves me little room for having options in buying Bookshelf speakers (will be making another thread for them later).
Now even though I have put my budget considerations in my calculation, I urge you to refer to following terms of reference for recommendation:
- Looking at something that can handle both 4ohm and 8ohm loads with at least 50W per channel for both type of impedance load.
- Want Pre outs in the amplifier (or some sort of RCA output) as this setup would be mated to a Crown XLS 2502 Amplifier running a passive subwoofer
- Want amplifier to have some headroom for near future upgrade. But this is something I can compromise on if the amp is cheap.
- Norge 1000 Concerto Gold
- Sansui AU-X9500
- Onkyo TX-8050
- Performance
- Durability
- Features/Functionality
