Hi.
I have yamaha home theater with AV receiver Yanaha HTR 3067. AVR was working fine but suddenly now it has some problems.
It is automatically switching to FM input and then stop responding to buttons and remote. Then works fine for some time after restart.
Also it is sometimes automatically showing UPDATE USB on start up and then didnt respond to any command.
I have tried to reset it. But problem is not solved.
I sent the system to service center. But now they are saying that motherboard is faulty.
I need your advice I thought that as if all the system working fine except switching to FM mode automatically, it should be only software type problem and should be solved by so e kind of firmware update. However there is no firmware available on the yamaha Site.
Please help.
Please help.
