PSW10 @ $102 - good deal?
Its a good sub if you are on budget. I had a PSW125 and I liked it for the movies in my 350sqft room.
If you are carrying from US and if you've some more budget consider better ones like Velodyne or Polk DSW series. Or at least PSW110 instead of monitor series.
Why do you want to buy skimp even as you would be purchasing in USA?
Think in this way: Think of yourself being in India and set a budget. If you are open to spend 30k in India, buy something in US worth USD 400-500. That way you get a much better product at your budget.
I think PSW 110 will suffice my need and will be within my budget. It is approx. $ 155 and Velodyne impact 10 is over $ 350. Actually sub was not in my shopping list as I will be spending on the projector that I plan to get from the US but the price & discount on Polk audio sub was very tempting so thinking of going for it.
Finally landed up buying Velodyne Impact 12 from a dealer in Hyderabad as the price difference was not much when compared to Amazon US. Thanks again for your inputs.
