spirovious
Still not available in Mumbai, alpha or fairdeal.
Hi All,
I heard from a dealer in Mumbai that Pioneer is going to launch new BDP in India this month end or early Sep. Don't know if this means BDP-180.
Anyone having any info?
Hey,
I'm using my BDP 170 for my music playback from USB inputs; very good output.
I'm using BDP HDMI out to an Onkyo entry level AVR with Pioneer FS-52 speakers. I never tried the onboad DAC of the BDP -170; i suspect that might be better than ONKYO?
I'm planning to get a stereo setup. thinking of Marantz PM 6005 and KEF Q 300; connecting BDP 170 to Marantz Coaxial input. Hope this will give better audio output.. what you guys think?
When I am using this BDP for music it plays only music CD and when I try to use USB it did not detect. Are you using TV screen for navigation or how you are choosing USB input. Can you explain me so that I could use this properly. I request other members to help me to understand how can I use this to play songs from USB or MP3 disc. Many thanks in advance.
No one seems to be interested in spending some time for this sily question, or may be my query is not rightly narrated.
If you go to main/ home menu (by navigating through TV) it should be shown there as USB, then you choose that to play music and navigate your playlist.
If you chose it as movie then you cant play music.
If still that is not showing/ working then format your USB in preferred file system as NTFS and copy your playlist again. I hope it should work.
Cheers, Amit![]()
Yes,I forgot to mention that if you want to play audio files,then select Music in the pioneer menu.Then select music file to play.Other files(say video) cant be played.You have to go back to main menu and select video option,then search for video files you want to play.Thank you very much, I will try today, hope this will work.![]()
Yes,I forgot to mention that if you want to play audio files,then select Music in the pioneer menu.Then select music file to play.Other files(say video) cant be played.You have to go back to main menu and select video option,then search for video files you want to play.![]()
a Correction,you will not need a PC remote(wont work with BDp),pioneer remote will do the job.The best is to use PC screen with HDM and a PC remote to select it.
http://www.hifivision.com/audio-video-accessories/7209-pc-remote-review.html
Pioneer BDp is out officially in India?
Brand NEW Pioneer BDP-180 Blu-ray Player - Mumbai - TV - Video - Audio
Looks like gray stock. BDp-180 has 4K upscaler. Coaxial replaced by optical out.
Since its gray,you try to get better priceI have messaged him, he is ready to ship to pune, waiting for review from anyone pickups or buys
