surajts
How is Yamaha R-N303 Stereo Receiver?
Can we get good performance with Polk T15 speakers ?
Currently I am using my Polk T15 but it's not enough to create much powerful bass so I am planning to add a floor stander to the main hall which is little bigger in size 20/8 feet with roof double height (balcony).
Source of music CD,media player,laptop,mobile etc.
And my av receiver is Yamaha R-N 303 .
Please advise it's my plan to have a entry/medium level speaker may be maximum of INR 20k.
Or may be you could suggest better one with slight price variation also.
Thanking you.
SURAJ TS
Possible look for Active sub with Hi level input model.Hi, I would like to know weather this Yamaha R-N303 Amp can support a Sub woofer or not ?. If yes then weather it is Passive or Active ? and how to connect ?
Hey, I'm looking for a new stereo amp and considering this as one of the option as it will simplify my setup. Did you end-up purchasing R-N303? What was the price in Hyderabad.Possible look for Active sub with Hi level input model.
Passive sub will not work for Yamaha R-N303
HiHey, I'm looking for a new stereo amp and considering this as one of the option as it will simplify my setup. Did you end-up purchasing R-N303? What was the price in Hyderabad.
