RCA Interconnect Cable recommendation
ajuvignesh
Kanyakumari
I have a budget of Rs 10,000 for a pair of RCA interconnects to connect my DAC to my Poweramp. I am currently using Belden 1694F with MX rca connectors and I will use each as a digital cable from now on. I am considering these four cables to connect my DAC and Poweramp.
  1. Belden 8402
  2. Mogami 2803
  3. Mogami W2497 Neglex
  4. Pangea Premier Interconnect.
I love tight bass, a meaty midrange with decent treble sparkle. I will also have a minidsp SHD studio dirac live room correction system in the chain. So, which cable will be a better pick?
My vote to the pangea, have used it in the past and when my second setup is up and running again will start to use it again. In the bass its very detailed though quantity might feel less, in the midrange seperation, and clarity is the main attraction, male vocals have good heft, the treble is where I find it lacking some refinement and a little veiled. But at the price offered its good for what it's doing.
Thank you :) Pangea is known for its power cables. Good that they are performing well in the Interconnect department as well.
  1. Belden 8402
  2. Mogami 2803
for tight bass, a meaty midrange with decent treble sparkle.
Furutech Alpha Line Plus - Audiophile RCA Interconnect Cable​
I am using the Mogami 2803. I felt the bass “bloat” was definitely reduced. One could also call it tight or lean, but as many things in this hobby, things can get pretty subjective :). I didn’t like the lean bass the first few days after I switched to Mogami, but I guess I am used to it now. The treble too is well separated, but slightly understated.
Thank you so much, Nagaraj. How is the midrange?
Mogami 2549 has some magic , try it once.
Ping Ali from soundfoundation and ask him some of the ICs for home trial. TC applied.
I have been using Mogami 2549 since last 2 yrs and happy with it.
Here is a dedicated thread for same
I have also some ICs lined for auditioned from soundfoundation.
Chandu
Chandu
Thank you. I got myself a 2803. Happy with it. Having said that, will take your suggestion and try 2549 later sometime.
  1. Belden 8402
  2. Mogami 2803
Pangea Premier Interconnect would be my pick from the options you mentioned.
How is 2803. Iam looking for rca to connect avr and power amp. In between 2549 and 2803
I am not sure if RCA will play bigger role while connecting avr to power amp, but that's my opinion.
They are here and currently burning...will update here once I have some critical listening done, They are connected b/w dac and preamp.
it's nice. In my opinion, it is flat and slightly tilted to treble and bass presentation. great details. My system is not dynamically sound. So can't comment on it.
