Recommend me a USB cable....100-700$ range
Quick googling and reading reviews I have come up with these candidates:
FTA Callisto - 800$
Phasure Lush 2 - 300$
FM Joshua cables - Not Available for now
inakustic reference - 300$
Anyone have any other recommendations, I prefer to buy local from a dealer or an FM, kind of burnt out from dealing with customs and import.
If anyone is selling a nice USB Charging cable wholesale, do kindly PM me.
Budget is flexible but would like to keep it under $500 if possible.
Hello. Just got a TEAC A H01 DAC + Amp and now using a HP printer cable which i think sounds really crap. I scrolled some post regarding this topic and found out it dosen't worth spending loads of money in a usb cable. i have around $60 budget and basically Im finding a cable which can give me deeper and wider sounds stage, also clear overall picture and mid range. Thanks
The Pangea Premier cable is quiet nice at this price range, if you have a dedicated 5v lpsu then the dual headed premier XL also is an option
