Recommendation for LPS for Network Switch
rajivaryan1984
INDIA
Hi FM's,
Recently reading a lot about clean power in the network. Therefore, looking for a recommendation on using a LPS for "Netgear GS324-100INS Gigabit Ethernet Unmanaged Switch" which needs 240 VAC, 1A, 50-60HZ..Any recommendations pls...
Hi FM's,
Not sure what your budget is but check the DC voltage of the switch and see if you can start with SBooster and if can stretch further, Farad Super3.
It has inbuilt switch mode power supply from wall socket, Not sure how LPS will fit here unless it takes DC.
Thanks for pointing this out. This can still be done but would require a higher level of skills but, the question is, why does @rajivaryan1984 need a switch with so many ports? I would recommend replacing the switch with a smaller one with less number of ports and the one that can take DC in.
