Thanks Raghu.
Another doubt I have in mind is my living room is 10.6ft x 22ft. The speakers will be placed against the long wall. Will it appropriate to buy an Chorus 816 which is 2.5 way and 3 drivers as against an 826 which is 3 way and 4 drivers.
Your room dimensions are tricky. Kinda "damned if you do damned if you don't scenario"
Placement along the short wall will force you to leave space from side walls, thus reducing spacing between speakers.
Placement along long wall will reduce sidewall reflections but put speaker plane very close to listening position.
Assuming that long wall placement is what you will end up with, why towers?
Even front ported speakers, like Focal 800 series, will force you to have the speaker plane 2 feet from back wall.
A sofa against the opposite wall will eat up up to 3 feet.
Meaning your listening position is about 6-7 feet from speaker plane.
Towers in this scenario may be an overkill. Stand mounts may be able to deliver well enough in this scenario.
I have heard Focal 700 and 800 a few years ago with Denon. Not AVR but the IA range. Great combo.
Raghu
