saketgyani
Hello!
I started my vinyl journey a couple of months ago and absolutely loving it!
I have a Rega Planar 1 (Eco-Deck).
The phono leads (RCA) are hard wired into the tone arm (hence the cartridge) and are of really flimsy quality.
I was fine with that but now I'm changing the placement of the turn table and I realised, the RCA leads from the TT are pretty short and cannot reach the integrated amplifier (I'm using the inbuilt phono preamp of my amplifier).
So I tried extending the phono leads using these Male to Female RCA adapter cables. Turns out, they are not shielded and there's a humming sound every now and then. I fiddle around with the adapter cables and the hums goes, only to return in a few minutes. Definitely returning these.
I'm thinking of modifying the turn table. Is there a way to get rid of the stock RCA cables that come from the tone-arm and instead install a pair of good quality female RCA sockets at the back of the turn table? That way I can use the RCA interconnects of my choice.
Can someone recommend a solid technician to carry out this job in Bombay?
Thanks!
Thanks!
