Hello,
Would like to request advice to select the right Stereo Integrated Amplifier
I have a spare pair of Wharfedale Diamond 220 bookshelves. I am thinking of using them to create an audio setup in my open terrace. Its 800 sq.ft open space (partly covered on top) and I do know any simple setup will not be great but at least something which can give medium loud music for the a party (around 15 sq ft from speakers, 10-15 people) will be enough !! anyway don't want to get a noise compliant !!
I did some looking around (this forum, google) and within a 25K budget (can stretch little) I could find below options. Input will be via phone - MP3 / FLAC / Spotify / Amazon Music etc. Would like to have Bluetooth and a remote control for volume. Please advice which one would be best. I dont really understand the Watt -Ohm !!
1. Yamaha RS-202 Stereo Receiver with bluetooth. Approx INR 21K (has remote). 100W @ 8 Ohm. Availability seems limited.
2. FX Audio M160E Amplifier with bluetooth 4.0. Approx INR 8K (has remote) 85W @ 8 Ohm
3. FX Audio D502 integrated amplifier. No Bluetooth and will need to add something like TPLink (INR 3K) or higher end Auris Blume HD (INR 9K). But interestingly it has a sub-woofer pre-out to connect active sub-woofer. If it can be loud enough I would like this option but loudness I cant figure out as its only 45W @ 8 Ohm and much lower than other options.
4. Norge 2060 amplifier - no remote. Approx 18K ? (dont know). The bluetooth 2060 UBT version (with remote but no volume change) read somewhere the bluetooth is buggy so will avoid. 65W @ 8 Ohm. Will need to add the bluetooth device so will go INR 22-27K. Then all other options seem to be better !
Will greatly appreciate your advice on the above and if you can make some different suggestions within the budget. Looking forward to hear back
thanks
RJ
thanks
RJ
