Request for help with suggestions for a FM antenna
newlash09
hyderabad
I recently bought my first FM tuner used from abroad. It has only one antenna connection, labelled 75 ohms. Which looks like a threaded female connector. Been looking for an antenna to connect to this input. My system is just 3 mtrs from my flat window. I plan on mounting this antenna out side this window. So don't really need a long run of wire.
Been searching on Amazon but the different connectors being offered have got me really confused what to buy finally. It will be very helpful, if anyone can post some links to some antenna's suitable for my purpose, so i can purchase by following the link. Thanks in advance for your time..
Please check this link below.
If it is not the same, better u share the connector image for suggestions.
FM Antenna
