Request for help with TV purchase decision
I wanted to buy a LED tv, iam confused which one i should buy? I have selected Toshiba 23PU200 LED 23" Full HD Television and Panasonic TH-L24X5D LED 24 inches Full HD Television. Please suggest the best option from these two?
At that small size, full HD does not make much difference. Do a close comparison on picture quality. Buy what is in your budget. Please note that resale value of 24" TV is very low. 32" resale value is much more.
People,
Need a quick input
Which of the two would preferable:
1. 600va UPS
APC Back UPS BR600C-IN 600VA with 2 Years onsite Warranty with Invoice | eBay
APC Back-UPS 600, 230V without auto shutdown software, India
2. 1kva voltage stabilizer
V-Guard VG Crystal Voltage Stabilizer For LCD / LED / Plasma TVs / Home Theatres | eBay
V-Guard DIGI 200 Voltage Stabilizer For LCD / LED / Plasma TVs / Home Theatres / | eBay
http://www.vguard.in/pdfs/digital_tv.pdf
The price points for the two would be similar
Though we don't face much of shutdowns or fluctuations, however insurance is an insurance
Looking forward to your inputs.
Anshul
Experts,
Though did not get any inputs, over the weekend, I added a 800va UPS in the setup. I had this UPS for sometime, however the batteries needed replacement. I replaced the battery and put the UPS in the setup.
No way to measure, and therefore do not feel the change.
Anshul
Guys,
Need help.
I downloaded a Avatar video in 1920 x 1080 format (mkv container)
I tried playing the file using a external HDD on my panasonic UT50 and it would just not be able to play it. It would show on frame, freeze on it and sometime late a prompt would say "Cannot Read File". Tried using Tsmuxer to change to other format, but no success
Whats the challenge here - HDD, File Format or the TV
How do I play good quality movies????
Seems like codec or mkv version issue. The latest mkv version uses header compression which isn't supported by some players.
Open it in VLC and use CTRL+ I. It will display file info ; post it here. Have tried playing any other mkv videos?
Thanks @k2max6
Will definitely give this a trial today at home and report. Could be the potential issue
People,
Here is the mediainfo (as reported by MediaInfo tool)
1.
General
Unique ID : 210081623947578939272169528372150114389 (0x9E0C3FC099F527A984D72500EA7B9855)
Complete name : T:\HD movies\Avatar\Avatar.mkv
Format : Matroska
Format version : Version 2
File size : 10.8 GiB
Duration : 2h 58mn
Overall bit rate : 8 699 Kbps
Encoded date : UTC 2012-05-25 15:08:01
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 10 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 58mn
Bit rate : 6 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.121
Stream size : 7.23 GiB (67%)
Title : Avatar 2009 Extended 1080p DTS multisub Ger Hun HighCode-PublicHD
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=128 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=150 / rc=2pass / mbtree=1 / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 58mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.88 GiB (17%)
Title : DTS 1500
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 58mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Stream size : 961 MiB (9%)
Title : DTS 768
Language : German
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 58mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 571 MiB (5%)
Title : DD 448
Language : Hungarian
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : navi parts only
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Title : sdh
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Bulgarian
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Croatian
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Czech
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Estonian
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Finnish
Default : No
Forced : No
Text #10
Format : UTF-8
Language : French
Default : No
Forced : No
Text #11
Format : UTF-8
Language : German
Default : No
Forced : No
Text #12
Format : UTF-8
Language : German
Default : No
Forced : No
Text #13
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #14
Format : UTF-8
Default : No
Forced : No
Text #15
Format : UTF-8
Language : Italian
Default : No
Forced : No
Text #16
Format : UTF-8
Language : Norwegian
Default : No
Forced : No
Text #17
Format : UTF-8
Language : Polish
Default : No
Forced : No
Text #18
Format : UTF-8
Title : BR
Language : Portuguese
Default : No
Forced : No
Text #19
Format : UTF-8
Title : IB
Default : No
Forced : No
Text #20
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #21
Format : UTF-8
Language : Russian
Default : No
Forced : No
Text #22
Format : UTF-8
Language : Slovenian
Default : No
Forced : No
Text #23
Format : UTF-8
Title : Castillan
Language : Spanish
Default : No
Forced : No
Text #24
Format : UTF-8
Title : Latin
Language : Spanish
Default : No
Forced : No
Text #25
Format : UTF-8
Language : Serbian
Default : No
Forced : No
Text #26
Format : UTF-8
Language : Swedish
Default : No
Forced : No
Text #27
Format : UTF-8
Language : Turkish
Default : No
Forced : No
2.
General
Unique ID : 243656665507582995962216181732606996745 (0xB74E911B7276AC249860277AFE9FF109)
Complete name : T:\HD movies\SHORT CIRCUIT\Short Circuit.mkv
Format : Matroska
File size : 4.10 GiB
Duration : 1h 38mn
Overall bit rate : 5 958 Kbps
Encoded date : UTC 2012-11-18 13:01:09
Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format settings, ReFrames : 9 frames
Duration : 1h 38mn
Bit rate : 5 200 Kbps
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.113
Stream size : 3.50 GiB (85%)
Title : Short Circuit (1986) BDRip 1080p HighCode
Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=2pass / mbtree=1 / bitrate=5200 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:2.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 38mn
Bit rate : 755 Kbps
Bit depth : 24 bits
Stream size : 532 MiB (13%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Russian
Default : No
Forced : No
3.
General
Unique ID : 193572296560776449645371441121779962195 (0x91A0AB1173476559A940DC39343ED153)
Complete name : T:\HD movies\SHORT CIRCUIT\Short Circuit 2.mkv
Format : Matroska
File size : 4.70 GiB
Duration : 1h 50mn
Overall bit rate : 6 093 Kbps
Encoded date : UTC 2012-11-18 13:16:16
Video
Format : AVC
Duration : 1h 50mn
Nominal bit rate : 5 900 Kbps
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.123
Title : Short Circuit 2 (1988) BDRip 1080p HighCode
Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=2pass / mbtree=1 / bitrate=5900 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:2.00
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 50mn
Channel(s) : 2 channels
Channel positions : Front: L R
Title : aac-lc vrb 192~213
Language : English
Default : Yes
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Title : VobSub PSDH
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Title : srt
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #5
Format : UTF-8
Language : German
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Russian
Default : No
Forced : No
Menu
00:00:00.054 : en:00:00:00.054
