How much it costed???
Including all the things and did you find price for 1.1 ton pht
Hi IronHorse,
Was the copper piping included with your Inverter Ac device? Here at TMC Kukatpally they tell me that i needs to Rs 750 per mt. besides the installation charges of Rs 1500 & ODU Bracket worth Rs 800 for an inverter AC. I had inquired both for 'Digital Inverter AC AR12HV5NBWK 1.0 TR' & 'Sharp AH-XP-13PHT 1.1 Ton Inverter Split Air conditioner'. Not sure now as the additional themselves are somewhere in the range of 4K.
Kindly advise.
Sanju,May be felt a little bit of skeptical in this thread which seems like advertisement of Inverter AC and Sharp...... no offense ... just kidding......but I have a small question ..... Do I really need to spend around 15-20 k more if my AC usage is just for 3 months 5/6 hrs daily . Does it really save that amount of billing to reach a break even point considering a life span of 6 years maximum before some more new concept will be injected in the market and we will start discarding the "Inverter" concept. Can anybody reply categorically with respect to the specific usage pattern mentioned above.
Sanju
to clear your doubt.. the diffrence is not 15-20k or to be true there is not diffrence at all
1.1 Ton invertor= 1.5 standard AC.. ( going by stats and company info)
1.5 T hitachi ( considered good) my friend bought is = 36k
1.1 T sharp invertor AC i bought = 36k...
now please see if there is any diffrence.. for the first look it might look like advertizing something but as a FM i believe you have all the permissions to check a user profile.
check the threads that rishi have put up for
yamaha z9
norge 1000 gold
logitech z xxx.. these are the ones on my finger tips you might have a diffrent opinion then...
now whether you want to buy a standard or invertor its all your call however
i will tell you the stark diffrence i have felt in terms of comfort..
on my 1.5 T LG in other room i used to sleep with a blanket while setting temperature at 24. if it set it to 26-27 it will cut off very quickly and i would feel hot/warm and was unable to sleep. by setting to 24 it was too cold and i would need a blanket for peaceful sleep due to the huge variations in temperature with the on-off cycles.. and huge wastage of electricity as 24 C was never usable for me. i would use the blanket to keep warm...
coming to sharp or any other invertor AC.. i keep the temperature at 26 or even 27.. sleep in my shorts and just a thin satin bedsheet.. extreme comfort. no sound. i might be going deaf slowly i assume but the ac is inaudible to me if i may say... no sound what so ever...when fan is on auto...its as good as a turned off unit... no wastage of electricity by putting temperature to 24 and again using blanket.
so your average temperature moves from 24-27 ( energy saving)
blanket dry-cleaning every cpl of months(hygeine) = nutin short of 600-700 bucks
comfort of sleeping in open air without any weight...
cost is same like other brands of infact cheaper...
1.5 T vs 1.1 = cost saving...
now think about it again if this is an advertisement ..
yes i am saving a FM's grace here for i should. Forum is nutin short of a family/close friends now, after being here for so many years..
i doubt even a company rep will do this much r&d as for them its a job.. for us its a passion and hobby
Hi IronHorse,
Was the copper piping included with your Inverter Ac device? Here at TMC Kukatpally they tell me that it needs procured separately for Rs 750 per mt. besides the installation charges of Rs 1500 & ODU Bracket worth Rs 800, for any inverter AC. I had inquired both for 'Digital Inverter AC AR12HV5NBWK 1.0 TR' & 'Sharp AH-XP-13PHT 1.1 Ton Inverter Split Air conditioner'. Not sure now as the additional items themselves are somewhere in the range of 4K.
Kindly advise.
i doubt even a company rep will do this much r&d as for them its a job.. for us its a passion and hobby .
There was a suggestion in previous posts that the AC shows power consumption rather than the set temp on its LCD . The one I have clearly shows the set temperature on its LCD.
Do it also show the live wattage consumption??
Are those 4 additional features as compared to PET model have a justified price increase as compared to PET model
Which stablizer did you buy and what is its voltage range
Any special thing to keep in my mind during installtion
any other info apart from the above will be helpfull
@peet_dhev
In Thane, Mumbai i was getting 1 ton PET for 36,000 including free dealer installation which was lowest. (stand Rs 800 extra).
Several other dealers where ready for around 35,500 excluding Rs 1500 official Sharp installation extra.
Finally took the plunge and bought a 1.1 AH-XP13PET for Rs. 35150/- excluding a stabiliser.
Really appreciate all the help and guidance.
Whattttt i got 1.1 ton PHT for 35900(ac cost)
Hey Iron horse,
Need your help mate. TMC Kukatpally tells that it is not possible that you got your Sharp 1.1 XP13PET for 36K. They have challenged me now and I would appreciate if you could guide me here.
