Subbu68
My current sources are a CDP, tape deck and a iFi Nano DSD USB DAC all feeding a tube preamp Elekit TU8500. Amp is a pair of ACA in bridged mono OR Elekit TU 8200.
Music is on a Synology NAS..also residing on the HDD of laptop. Also using YT Music.
Earlier I had been using a Mac Mini feeding the DAC. The TV was the screen. That was cumbersome. So many things to switch on and a wireless KB and mouse to store extra.
Then started using a Surface Pro tab instead and now a laptop instead of Mac Mini.
The issue is, there is no remote control for the music i.e, selections, play, pause, volume etc.etc. So a long USB cable connection to the DAC from the PC is a must from the sofa I sit on. Cannot leave that cable there after the sessions - trip hazard.
Sorry for the long rant but had to state the problem and background.
If I made a RPi + HAT DAC or use a RPi with existing DAC can it be controlled with a phone? Or is there any other solution that can be used with mobile phone or a tab? Prefer a DIY. I am not in for a BT receiver at the preamp.
I use Android (Pixel, Nokia 8.3) on Droid 12.
