Samsung 3D TV vs LG 3D TV
handsydude
I am going to buy a 3D TV soon. Looking out for Samsung 6 series or LG 4 or 5 or 6 series models.
Would like owners of these types of 3D TV to give a detail info of your model the advantages and disadvantages in 2D and 3D image quality.. and also overall how you are satisfied with your product..
Watched some videos related to the series I have mentioned what I found
LG
Advantages :- Passive 3d viewing so can move your 3D glasses to any angles you like , their 3-d glasses are cheaper and also if you want 3-d glasses of another brand it would be in a range of Rs 200. 3d glasses of lg are very lighter and non-battery operated
Disadvantages :- Since the 3d glasses are lighter in weight so they do tend to break easily if not taken care . Input Lag is seen in most of the models of these series . Also many people had other screen related problems due to which they opted for a replace.
Samsung:-
Advantages :- Better clarity in 3d viewing if you keep your eyes in a range of 90 degree to TV all the time. 3d glasses are well built comparatively so wont break easily .
Disadvantages :- It is heavier and also when it has low battery then it decreased the 3d pq. Also it is costlier to buy will cost more than Rs 2000 also. Also if you lay down in your sofa for watching 3d hd movies then you wont see anything as if the angle is not around 90 degree to the screen then the glasses turned out to black.
Passive 3D can be viewed without flicker in a bright environment. Active causes flicker.
Active 3D is full HD. Produces crisp and more effective 3D. Passive loses some resolution and looks soft. 3D depth is good though.
Btw, who would watch 3D lying? As if watching through glasses with family is not enough a weired thing. Some active 3D sets causes crosstalk and darkened images with tilt of head. Sony is biggest culprit. Active 3D on Samsung's higher models are superb.
Sent from my HTC One X using Tapatalk 2
I can share a recent experience: when demo-ing a Sony active 3d tv (one of the latest and expensive models), the movements were "jerky" (like it was happening at a lower fps). But with the glasses off the movements were smoother (although with the double image). The video being played was an official Sony demo clip. I don't know if it was the 3D shutter which was causing the problem or something else, but I concluded I don't want to go the Active 3D route.
Moreover I don't like Active 3D glasses, even the lighter ones are heavy and not comfortable for extended viewing. And if you have kids who may want to watch 3D content - forget it, they're way too big, bulky, heavy and uncomfortable for them.
These days you can buy 5 to 20 passive glasses for the price of one active set. One consideration if you want more glasses at home.
I was not too concerned about the resolution as I plan to sit about 12' away from my screen.
Sorry to not answer specifically about LG or Samsung, but these technologies are so vastly different, that you should first decide on this matter - that is if 3D is an important requirement.
i almost decided to buy LG 3D led lm6700 plz someone give feedback on this model... and best price. i couldnt find even a single owner of this model in this forum..does it mean LG LEDs are not that much gud?
If you can't find any owner thread, that doesn't mean LG LEDs are not good. LG is a big brand and I am pretty sure that they would be having quality products.
I am a supporter of Passive 3D. It is just that I prefer the PQ of plasma more. If there was a plasma with passive 3D, I would have opted for it.
Coming to LG 3D TV's, I am sure that they are good. But I think that they are very overpriced. In my opinion, the price is inflated by 15% at least. The low cost of passive 3D glasses is almost offset by the overpricing.
I don't think LG 3D TVs are overpriced. I just compared the price range of both the brands on naaptol and flipkart and I find LG to be cheaper than samsung.
Also LG is giving free 3d glasses with their 3D TV's(number depends on models) while there is nothing as such when it comes to samsung..
Arun, frankly last models were better than this year's LM series. If you going 42" then it you may not notice too many issues. The higher sizes are not worth it unless 80% of your viewing habit is dedicated to 3D.
3D is just an add on option to have fun once in a month.. and also i am preferring passive 3D. and the main thing is i want to use it as a display of my laptop and to play games...and of course i want good PQ.. and i am searching for 42 inch only..i have no money for bigger size...
@Arun ,Just check out LG LM7600 model although little priced higher and the quality is too good.
@ Shaiju_O_thomas, I wont agree with 'garbage quality' comment from you...:cool: Maybe you had seen a TV which have issues, so cant blame the entire product range.
@Arun,
So go check yourself in the showroom to make final decision... IMHO, LG is a superior product with best 3D feature. Period!
Shaiju is correct above 2d quality. But wrong about flicker on active. 2012 lg models are overpriced.
Sent from my GT-S5830 using Tapatalk 2
I had a 55LM6700 at home for more than a week. Also did demos of series up to 7600. So I do know what I am writing.
If you are happy with LM series, good for you. Just because I have negative opinions doesn't mean no one will buy or LG will shut shop. I write again that the LM looks are deceiving to ignore it.
I did demo of the Samsung 55ES6200. It is more capable than LG I had. Only slight over sharpening issue was a disappointment. It's available for similar price. Sony and Samsung outdoes LG.
Active 3D filckers in bright light conditions. That's what I meant. Under controlled lights it is more sharp and detailed than Passive.
This year LG models aren't that good at all. No great reviews on any major site. All of them criticize the 2D PQ.
3D is of course good but not Full HD 3D.
I would suggest you buy Panasonic Plasma or look at Sony Bravia 40HX850 or equivalent Samsung model.
If you are happy with LM series, good for you. Just because I have negative opinions doesn't mean no one will buy or LG will shut shop. I write again that the LM looks are deceiving to ignore it.I did demo of the Samsung 55ES6200. It is more capable than LG I had. Only slight over sharpening issue was a disappointment. It's available for similar price. Sony and Samsung outdoes LG.
Bro, Rightly I said you had issues with your LG TV(one of a case), so kindly do not blame the entire product range. "Garbage Quality" was a bit harsh in your comments.
If looks are the only thing people get carried away(deceived as per ur comment), I might ended up with Sony Monolithic designs, they were simply the best. Still i went for LG. Bcoz technically superior.
Still 'Active shutter' is technically inferior to 'LG's passive Technology' Meaning LG's is far better 3D technology than Sam/Sony's...:rolleyes:
Even though active 3d is full hd while passive is half hd, I will recommend passive 3d from personal experience. This is considering that 3d is important to you.
Active 3d is tiresome and more prone to headaches, etc.
Sent from my GT-I9100G using Tapatalk 2
i own an es 6200. full hd 3d is awesome plus no problem on 3d for hours.
