samsung eh5000 owners please help
manu george
kottayam
Hai members I am planning to buy samsung eh5000.my avr is denon 1612.I am planning to connect my 1612 and eh5000 via optical out for dts and dolby decoding.I want to know;it is possible or not.
I just found found it only stream 2.0 dts and dolby through optical out.
please give your valuable advises.
dts 2.0+Digital Out (dts 2.0 only)
please members I just want to know can I get dts and dolby bitstream through optical out from eh5000 to my avr.if anyone in this forum know it please help.
Firstly, does your tv get 5.1 from the source?
Are you playing 5.1 content from usb?
Friend forget about the decoding capabilities of the any Display as far as sound concern. No TV can't decode any 5 channels or 7 channels as of now. Connect the Hdmi into your avr and Hdmi out to TV, the avr will take care of everything.
TV can decode upto 5 channel information and play it in 2.0 mode...Samsung is one of the fewer TV in the market that can decode both if you don't have AVR...
Thanks for the info mate that's really cool. I still believe it can only pass through. So Do you think If we have AVR with Preout or a 5 Channel Amp, will the TV take care of the decoding? I don't think so.
I am confused with the specification.
dts 2.0+Digital Out
Yes (dts 2.0 Only)
I think it will only pass 2 channel audio through optical out to avr.
I have seen many posts wherein people have connected STB, TV and HT as follows:
STB ==> (HDMI) ==> TV (HDMI ARC where available)
TV ==> (Optical) ==> HT
I cannot ever fathom this wierd connection method.
  • The best method is:
    STB ==> (HDMI) ==> HT ==> (HDMI) ==> TV (HDMI ARC where available)
  • HDMI ARC returns the audio via the same cable but TV's optical out will be 2.0 channel only. The TV will decode 5.1/7.1 channel DD/DTS/D-THD/DTS-HD-MA/LPCM sound and convert it to 2.0 audio for its internal purpose. The same is output via headphone and optical, coaxial or other means.
  • Sometimes, the HT does not have HDMI-In/Out. In this case, use the signal from STB. The STB also has optical and/or coaxial out. Use this:
    STB ==> (Optical/Coaxial) ==> HT
  • If your HT does not have HDMI-In or Coaxial/Optical In, then you are simply out of luck. You will never be able to get 5.1 sound from DTH STB. Time for you to upgrade.
Guys, he just want to know if 5.1 DTS or Dolby Digital passthrough is possible through the TV's optical out or are they down mixed to 2.0. It is useful when playing movies from the USB port. He owns his avr for more than an year and I'm pretty sure he knows how to make the connections work.
Ah. Now I can understand the issue.
So a dolby/dts 5.1 encoded file on the usb has to be bitstreamed via optical by the tv.
If the tv can bitstream audio, I cant understand why it is only limited to 2.0, as it should just consider the sound as raw bytes and transfer it over optical without interpreting it as 5.1 or 2.0.
my all friends I have planned to buy samsung 40e5000.
So I dont want to take risk.thats all.
I just want to know can the eg5000 bitstream 5.1 dts and dolby digital formats to avr. thats all.
usb or hard disk to led (with 5.1 audio dts or dolby digital)>optical out>avr(decoding through avr)
dear all.. thanks for all ur inputs.. am in big time confusion.. please conclude my research..
1. Samsung 40EH5000
or
2. Sony 40EX430
or any other preferred model by you guys ?
been doing lot of research but could not conclude.. am n gulf, and am getting both are in cheap prices. (Sammy 40EH5000 - 28675 Rs and Sony 40EX430 - 32250 Rs). i am scared with the playable format in sony. other than sony looking owsome to me.
and also am not that tech savyv to use the tv enough, am not aware of the picture quality too. so pls conclude me with your valuable reasons and suggestions for the money am going to pay.. need ur help guys.
basically tv is to watch cable tv channels for my parents. and sometimes, i ll play animated 1080p movies n tv, den good audio ll be enough. so as of now another concern is we are getting local cable tv set top box, so, watever the tv am gong to buy should deliver good video/PQ. so pls guys, conclude it for me.
awaiting your valuable reponses. kindly. thanks again, sharfudeen.
