i purchased a new samsung f8000 and suddenly noticed a light white cloud around the corner specially when switch on the tv and in black background, is this normal?
Nope.. This doesn't look normal... If you got the TV in india & still within warranty period, register a call immediately with technical support & see what best they could do...
If you are in warranty, get it serviced or better, get it replaced with a new piece.
Make sure you keep all the documentation handy and in place.
And by the way can't Invisible be made invisible? Only callous and boorish comments, is unable to add any value to any post, whatsoever, mods please will you note?
