SSD-based external drives come with digital noise generated by their internal control circuit. Any sensitive pre-amplifier may pick up those noises, thus compromising the overall audio fidelity. Audioquest JitterBug comes handly in this kind of use case to remove the digital input noise.SSDs are used by discerning audiophiles, since they sound better.
Same feedback about the quality of USB Optical HDD - WD better than Seagate. New Metal WD drives good. Gradually maybe we shall have to move to SSD.I would personally advise you against this approach ("reconvert to DVD").
2000 CDs ripped in wav will very easily be accommodated on a 2tb hard disk.
Flac files will take half that space but I personally feel that wav files sound better then Flac. This is of course a controversial topic and I do not intend to open a Pandora's box here on this topic.
I can confidentially say that no one has ever felt that wav sounds inferior to flac.
Hence you certainly do not lose sound quality by keeping all your files in wav.
2tb HDD is reasonably priced nowadays and you can even afford 2 hard disc of 4 TB each (for future rips) ...... one for use and one for backup
I prefer externally powered USB drives as they are bigger physically and more robust
I have personally had bad experiences with Seagate hard drives which have almost always died within 3 years. When submitted for warranty they replace with refurbished hard drives which again fail in less than one year so you lose your data TWICE!
fortunately I have had no problems with Western Digital hard drives which have proved very robust in use in my setup.YMMV.
From what I understand, WAV, FLAC, ALAC, AAC, MP3 are file storage formats.Converting Flac to wav before use .... I personally prefer this option, but its nowhere as good as a properly ripped wav file. Try it and see. A Lot will depend on your setup.
Each wav CD rip is approx 600 MB or 0.6 GB. Do the math for a 2000 GB (2TB) HDD.
Based on my observation, roughly 90% of the time, I failed a blind test between FLAC and AAC (320 kbps) derived from the same source and around 95% in the case of FLAC and Vorbis (320 kbps).Is there really a difference in what we hear? Or is it something that the encoding/decoding processes?
Ops, my bad, I misread your question. In audio world, probably its the most debated topic if you can hear the difference. In other forums, people say you have to train your ears to hear the difference. But I think, one can't trick the natural evolution and better to accept we hear less with age.@OM_2K19
I was asking this question in context of WAV vs FLAC or ALAC
Some folks can indeed identify lossless v/s lossy (FLAC/MP3 or ALAC/AAC). I definitely cannot.
In fact a few years ago I failed miserably in identifying 8-bit v/s 16-bit (let alone 24-bit)
I can relate to your experience in the blind test. Have a few rips from my own CDs into 320kpbs MP3 and FLAC
When playing back I can't hear a difference. Mine are ageing ears though, more recently they need hearing aids
Raghu
Media files can be played out of blob storage directly. That is all it a problem but it is too technical for home use. I agree make cloud your secondary.The cloud storages are mostly blob-based you won't be able to play directly from them. Use the cloud storage as Primary backup and use the HDD/SSD for playback.
In addition to the complexity, the Media Streaming service (Azure/AWS) will probably cost a fortune, probably a couple of times more than the storage price.Media files can be played out of blob storage directly. That is all it a problem but it is too technical for home use. I agree make cloud your secondary.
With different kind of music the experience was varying for me. Ear training is important and also the quality of machines. My some vinyls are from 1950s. The software failed to recognize what to keep and what all to remove during compression. Therefore,,,,,a listener shall be having combination of Vinyl, CD, FLAC, WAV etc. Its my opinion.Ops, my bad, I misread your question. In audio world, probably its the most debated topic if you can hear the difference. In other forums, people say you have to train your ears to hear the difference. But I think, one can't trick the natural evolution and better to accept we hear less with age.
WAV/FLAC/ALAC are all lossless encoding, so at the end, when they are decoded, we get the identical bitstream as the source. In the case of the FLAC, the compression comes at the cost of CPU overhead. Do they sound different? Theoretically, No, since they are lossless encoding. But since FLAC is CPU-heavy encoding, the sound fidelity may differ from system to system based on the DSP implementation.
Why SSD? SSD have limited writes and even at the moment are costlier than magnetic drives. The best approach would be to have all your music stored on magnetic drives (the normal 3.5 inch 10k rpm hard drives). Have SSD on the device that runs your player. The hard disks can be in a dedicated NAS device or connected to the USB 3.0 ports of Raspberry PI running samba, nfs-server. All your clients that need access to the actual files can run automount (if running linux or Mac OSX) or mount it as shared drive if using windows. So what I'm suggesting is a hybrid approach which gives reliability (that you cannot get using SSD as yet) and also performance of SSD (which hard disk don't provide)Hi,
I am looking to buy a External SSD to store my music and connect to my streamer.
Online searches show a number of companies selling SSDs with a range of capacities (128gb -2 Tb) Lots of variation in prices too.
Can anyone with some first hand knowledge advise on:
- what’s the “sweet spot” currently in terms of memory capacity and good value for money.
- build quality and reliability.
Over the years, the reliability of the SSD improved significantly and is currently at par with the Traditional HDD, in a few cases even better. With more adaption, the prices have also come down and will probably match the HDD in a few years.Why SSD? SSD have limited writes and even at the moment are costlier than magnetic drives.
NAS device isnt it too much for only music lovers? because each CD shall be in the range of 700MB (if not SACD), ? asking your opinion.Why SSD? SSD have limited writes and even at the moment are costlier than magnetic drives. The best approach would be to have all your music stored on magnetic drives (the normal 3.5 inch 10k rpm hard drives). Have SSD on the device that runs your player. The hard disks can be in a dedicated NAS device or connected to the USB 3.0 ports of Raspberry PI running samba, nfs-server. All your clients that need access to the actual files can run automount (if running linux or Mac OSX) or mount it as shared drive if using windows. So what I'm suggesting is a hybrid approach which gives reliability (that you cannot get using SSD as yet) and also performance of SSD (which hard disk don't provide)
