Dear Forum Member...
Wishing you all The Best for Independence Day.
I am from Mumbai....
As I have been observing since few days,I must appreciate the effort all you
have been taking to make the forum perfect & full of information in All fields of Audio video.Thank you for your inputs.A person like me who is novice in Technical terms in field of Avr/speakers/Tv gets lots of knowledge from Forum like this & support from guys like you all....
I Want your help in sellecting right systum for my Home Theatre Setup...
For My bedroom Size 15' by 12'.
First, for speakers 5.1 Channels Avr :-(50% Movies & 50% Music-Classical vocal/Solo Instrumental /Western Symphony Orchestral Music).
Preferrence,For front FS & Centre and surround for rear.
For Avr 5.1 channel budget will be Rs 30k..From Denon X 1000/Yamaha Rxv 575/ or As suggested by you...I will be getting Avr From Dubai....So i will save some money.
Followings are few Speakers which i short listed,But you can add your suggestion.
My Budget for Speaker Package is 75K....(If I need to increase my budget than i will add surrond or sub after some times).
1)Whorfdale Diamond 10 Series 102 to 10.7 & 100 series 121/122/155/156/157.
2)Dali Zensor 1/5 & 7.
3)Paradigm Atom Monitor S 7 bs or any other Model ?
4)Jamo.. you may suggest ?
5)Pioneer FS sp-bs 52 package..
6)Polk Audio Tsi 100
7)Q Accoustic 2020I Series.
Please help me to select right Speakers within my budget.I will highly appreciate your expert inputs...
Thanking you...with Warm Regards....
Rajubhai
Rajubhai
