Reason for opting for native 4k and not pixel shift?
It is in my budget, and native 4K does look a lot smoother than pixel shift.
What's your total budget? And is your audio budget separate from video budget?It is in my budget, and native 4K does look a lot smoother than pixel shift.
Projector budgeting seems high.. projector technology changes rapidly. 3-4 years later you will surely feel the itch to upgrade your projector.My total budget is around 20 lacs. No separate budget as such for audio and video.
Speakers and amplifiers last very long.
Are you willing to rethink projector choice?
Epson tw 9400 will be launched next month.
Check Epson 5050ub(same as 9400) projector review on projector Central. It might help bust a few myths.
The Sony VPL Series has a few native 4k projectors. Ideally, getting them from abroad will save atleast a couple of lakhs.
This is one option
Sony VPL-VW295ES HDR DCI 4K SXRD Home Theater Projector
Brightness of 1500 Lumens DCI 4K (4096 x 2160) Native Resolution HDR10 Compatible 2.1x Powered Zoom 1.38 to 2.83:1 Throw Ratio Two HDMI Inputs with HDCP 2.2 Support 3D-Compatible Onboard 3D RF Transmitter IR Remote Included Enjoy DCI 4K images in vibrant color with the Sony VPL-VW295ES HDR DCI...www.tanotis.com
Thats true. But see other options of getting the JVC if possible. The equivalent Sony ones are more expensive.Thanks! The JVC does have better specs though!
Older lcos projectors from sony had a panel degradation issue. Not sure sony has corrected it yet. Jvcs will be a better bet, imo.The Sony VPL Series has a few native 4k projectors. Ideally, getting them from abroad will save atleast a couple of lakhs.
This is one option
Check the review of 5050ub once.. Then finalize.I see. I have my heart set on the JVC only! I heard that for getting good quality, one should consider JVC or Sony only, especially when 4K and HDR processing is involved. I can see its a bit expensive though, let me rethink my choice one last time.
In this list Epson projector is the tw-9400 which will be launched in India next month.Best Home Theater Projectors April 2024
The best home theater projectors of 2024 that sell over $5000. If you want a huge 4k image that.www.projectorcentral.com
