dances_with_wolves
hi guys,
I have a entry level hi-fi setup consisting of a Sony DVD player (a stopgap arrangement), Marantz PM7001 integrated amp, and MA BR2s speakers. It is primarily for music. I feel the setup is missing some detail. The sounds seem bunched together. I am convinced the player is the weakest link. What say?
I plan to add some equipment with the intention of getting better detail from my setup - separate the sounds out more. For now, I am not too worried about bass, as I plan to buy a sub sometime soon.
I was wondering which of the below-mentioned two scenarios would improve the sound quality more noticeably. By improve, I mean detail.
1> Buy a better source. May be a Marantz CD player
2> Use the same source and buy a DAC
I want to know if a DAC will work with my current setup, and if you think it might be a better choice than changing the player. If a DAC, I shortlisted the V-DAC, Beresfords, and DACMagic. Any others I should look at?
I am in Canada now, where I plan to audition and buy some eqpmt. I will be here for less than 3 weeks. So, quick replies are really appreciated. Thanks.
cheers,
dww
cheers,
dww
