balavignesh002 Well-Known Member Joined May 27, 2016 Messages 554 Points 93 Location Madurai Dec 5, 2023 #41 sajeet said: Nice install Balavignesh, may I know the position of staging, is it over the dash or at ear level? Click to expand... Staging is bang on the dash, just above the AC vent.
S sajeet Member Joined Sep 10, 2014 Messages 60 Points 18 Location Chennai Dec 6, 2023 #42 Are tweeter pods angle adjustable?
balavignesh002 Well-Known Member Joined May 27, 2016 Messages 554 Points 93 Location Madurai Dec 6, 2023 #43 sajeet said: Are tweeter pods angle adjustable? Click to expand... Yes,
S sajeet Member Joined Sep 10, 2014 Messages 60 Points 18 Location Chennai Dec 6, 2023 #44 If you adjust the angle of the tweeters firing in various positions, do you achieve the staging & imaging beyond the dash, i.e., on the hood?
balavignesh002 Well-Known Member Joined May 27, 2016 Messages 554 Points 93 Location Madurai Dec 7, 2023 #45 sajeet said: If you adjust the angle of the tweeters firing in various positions, do you achieve the staging & imaging beyond the dash, i.e., on the hood? Click to expand... No
K keechlu New Member Joined Feb 16, 2022 Messages 3 Points 1 Location Under the sky Dec 15, 2023 #46 Hi, Which cable did you use to make the custom cable? You had used Mogami 3082, did you get a chance to use it in the car?
balavignesh002 Well-Known Member Joined May 27, 2016 Messages 554 Points 93 Location Madurai Dec 16, 2023 #47 keechlu said: Hi, Which cable did you use to make the custom cable? You had used Mogami 3082, did you get a chance to use it in the car? Click to expand... It's an OCC speaker cable which I have used in my cars. Please check this link I didn't try Mogami in car, if you want you can try. I can trade it to you.
