cool, cool.Won't fit the current bill, might get in next round.
All the best.
whenever you get around to it, please do drop your impressions here.
It's a very interesting attempt.
regards
10 (5 bed + 4 heights can be handled by AVR), for voice of God / top middle channel, need to use pre out and hence external amp.
4 towers bed, which are rated for 20-120 watts.
Read this in Omniman voice "That's the neat part" , don't want spend a lot for single channel yet. Maybe something less than 10k.
If I've to spend a lot, might do that in later round with more channels (5 atleast) to ease AVR from the towers.
I'm not sure that particular channel will ever need that kind of power, was thinking something like micca origain (5-7kish)So if I understand you correctly you need one channel of ~100W?
This might be tricky as mono amps are expensive and so are multichannel amps. You could try one of the cheaper pro amps like Crown XLS but even those are more than 10,000.
You might consider looking at OLX.
Please do! Thank you.If the origain works for you then great!
Happy watching/listening!
If I come across anything I'll post here.
IMO it’s better to invest on a decent 3 channel PA for the LCR which has the major impact for movies and also the most demanding. I have the Denon 4500 and going the DIY route for keeping it economical. The surrounds and heights can be easily handled by 4700.10 (5 bed + 4 heights can be handled by AVR), for voice of God / top middle channel, need to use pre out and hence external amp.
I'll definitely keep this in mind. Is your PA DIY or you got something off the shelf? As you already know, 4500 and 4700 are pretty close. Would like to follow your path here!IMO it’s better to invest on a decent 3 channel PA for the LCR which has the major impact for movies and also the most demanding. I have the Denon 4500 and going the DIY route for keeping it economical. The surrounds and heights can be easily handled by 4700.
Not me but there are few forum members who builds PA for a nominal cost. Do plan for a 3 channel PA for LCR which will give you much better results then adding PA for surrounds or heights. Adding a PA to all channels will be even better but for avr and PA combo LCR will be good enough for most.I'll definitely keep this in mind. Is your PA DIY or you got something off the shelf? As you already know, 4500 and 4700 are pretty close. Would like to follow your path here!
Thank you. I had gone through the following thread, before I joined. I think, I'll follow your advice and do the things the right way (atleast electronically) . There maybe more such gems hidden, but this is what I recalled.Not me but there are few forum members who builds PA for a nominal cost. Do plan for a 3 channel PA for LCR which will give you much better results then adding PA for surrounds or heights. Adding a PA to all channels will be even better but for avr and PA combo LCR will be good enough for most.
Yeah PA for LCR is the most common approach for HT.In the same thread you will have 3 DIY forum members who are well known for their good work. I have ordered a 3ch PA from Aniket in that thread. Hopefully by next month I’ll get it.Thank you. I had gone through the following thread, before I joined. I think, I'll follow your advice and do the things the right way (atleast electronically) . There maybe more such gems hidden, but this is what I recalled.
Thread 'Discrete Dynamics Class A/B Power & Pre-Amp - A New Star is Born' https://www.hifivision.com/threads/...s-a-b-power-pre-amp-a-new-star-is-born.73409/
Makes sense! Will do this instead of some break-fix solution for now.@imagineer
Getting an amp for only one channel is overkill. Shore up your budget and get a multichannel amp.
If HT is the primary usage, consider class-D. They will be sleek, have oodles of power and minimum cooling requirements.
Raghu
Moderators, please consider this thread as solved. Got an amp (100 WPC by TracAudio) for Front L&R. Another on the way (Volt+D by Allo) .Makes sense! Will do this instead of some break-fix solution for now.
@Love4sound @k-pad @RajithKumarModerators, please consider this thread as solved. Got an amp (100 WPC by TracAudio) for Front L&R. Another on the way (Volt+D by Allo) .
I'm afraid, I didn't follow you.Another way is to go by active route for VOG.
What he meant is to go for an Active speaker (powered speaker).I'm afraid, I didn't follow you.
Oh thank you... But, this is anyhow resolved now. I went for two in ceiling speakers powered by Allo Volt +D.What he meant is to go for an Active speaker (powered speaker).
