prateekagarwal576
Which of the current smart TVs has got the best internet features? I am looking between Samsung and LG.
Which of the current smart TVs has got the best internet features? I am looking between Samsung and LG.![]()
Smart TV is a complete waste. What does Smart TV enable you to do?
Buy the TV because of its basic features and qualities, MTBF (mean time between failures), service level/guarantee, etc. and not because it has better internet features.
integrating things to tv have never succeeded ...a standalone box i always much more powerful and flexible....
surfing net on tv rarely needed,for that a 3K android stick u can deploy ,dont put 60-80k because tv looks high end.. people go by 'better to have' thinking
what is bettter in that ?
photo browser ,gesture control - show off ,apps ?? mostly useless
3D: hahha where is the content ,1400Rs blurays ?Downloaded 40GB per movie frpom where ,do you have time to download ?
does is give better picture ? : user not sure
do they give better sound bar?:user unaware
is the remote is innovative : i dont think so
so what to buy .. ,dont just go gray market and check price theye will sale for 4k less MRP ,risk takers can get via proper import channels
I get full HD LEDs for 39K odd.. slim , 100Hz etc etc
Almost all higher end brand TV's offer the same features as the LG LM series. The only difference may be some may be wi-fi enabled (dongle required) or wi-fi built in.Most of the current crop of LED and LCD TVs are internet enabled, especially the range of Smart TVs. I prefer LG as the LM series Smart TVs provide a good deal of connectivity options unlike the limited range of other brands - built in Wi-Fi, 3 USB and 4 HDMI ports, wired LAN capability and the most modern feature - Intel enabled Wi-Fi, which will help in connecting our TV to your Wi-Fi equipped laptop.
1.smart living room show off -- yes
2.if you have 5Mbps net connection--yes
3. If point 1 ,2 not valid and you are smart --No
Dont join the less smart brigade, paying 20K for features that are useless and marketed a dump tv as smart tv
Have u checked transformer2,3...they are about 43-45 gb...
not all can sit with downloads all the time ,as there is less time for such adventures . only student like people can do .Am talking about 3. Btw people here should have access to private torrent sites, then they will understand how much of 3d contents and the size of them.
Sent from my GT-S5830 using Tapatalk 2
