With the help of esteemed d memebers, I was able to select FiiO BTA30 PRO pro for my music needs last year..
I primarily stream FLAC files over wifi through my Google chromecast audio to fosi amp.
Just to take it a notch up I am thinking of getting a DAC (a simple lower end one tbh).
I was wondering which one of smsl su1 and fiio bta30 pro would perform better as a DAC with noticeable enough difference as these two are the ones that I might be able to arrange.
I am aware fiio has BT function with lots of BT codec support but as I stream over wifi hence that function might not prove that beneficial to me.
Kindly share your experience and observations
