corElement
Re: Some thoughts
Are you talking about active near field monitors or a component system?
Because the variety you're talking about is the exact variety I'm talking about when you have a passive speaker and the option to take down the crossover and hook up individual amplifiers.
You can use Class A tube's to drive the tweeters while you can use a class A/B or D to drive the woofer.
This is something you cannot do in near field active monitors without taking them apart. Which is why everyone doesn't run for active near field monitors. Hence my reply to Oakley's blanket statements.
Active near field monitors are a practical no nonsense solution when one doesn't want to try out and match different sounds. But as soon as one want's variety, it's a waste of money to buy active, only to disconnect it's internals and hook up external amps to get that variety.
We are on the same page if you're talking about component systems Kanwar.
			What about the systems having active setup involving different amps for Highs, Mids, lows & Subs but no passive X-over but an active X-over as separate unit. ???????
This kind of active setup has much more options for variety of tastes to fulfill, much more than the passives could even offer.
