sony 46w950 @ 79,994
I have seen Sony 46W950A and Panasonic 42AS670D ( yet to see an 50"), I am now in fix to choose between these two.
While I have read reviews both have been rated more or less the same. I have negotiated the price for the 50 inch and 46 same at equal rate. Now what to choose? Please suggest and sorry for starting new topic.
Better start a new thread. I am not sure where 670D is rated equal to 950a. The only model which can be compared to 950a is the Samsung 8 series flat panel.
670D can be better compared to the other IPS panel displays
Did you try the settings ? what is your feedback ? Do post your settings too. Let me try that.
Thanks I used your settings looked good but a little dull for SD channels
For HD I used this settings
Picture mode cinema 2
Backlight 9
Contrast 87
Brightness 50
Colour 52
Hue 0
Colour temp. Warm 2
Sharpness 50
Extra processing off
Motionflow Clear
Film mode auto
Advanced settings
Black corrector off
Adv contrast enhancer off
Gamma 0
Led dynamic control low
Auto light limiter off
Clear white off
Live colour off
Detail enhancer off
Edge enhancer off
White balance
R GAIN -1
B gain -2
Backlight 9 ? U must be watching in a very bright room :D
For 3D, I have no idea because I am yet to see even a single Clip in 3D yet. For me 3D is just an eye candy.
Yup watching it in a well lit room, during night I reduce the backlight to 2-4
At what level do you keep the led dynamic control?
I am getting one at 49k, is it worth it?
Also i am getting 2 3d glasses. Can you tell what all accessories you got with your piece?
yes its worth for 49k
is it new or display piece?
I got 4 active 3d glasses, two remote controls and stand
