SONY BRAVIA KDL BX320..!! mkv format
rameshwaran
srilanka
Hi Dear Friends..!!
I have SONY BRAVIA KDL BX320. and i'm try to play mkv format movies :licklips::licklips: its working..!
and some mkv clips visuals is working but audio is not working.:sad::sad: it's saying audio format is not supported.:mad:
how can I play 1080p movies on that tv..:):licklips:
Get a blu ray player or another tv which plays mkv. Do research before buying tv's.
Sent from my GT-S5830 using Tapatalk 2
@rameshwaran No need to buy bluray player buddy just visit the post I mentioned...your tv is full capable of playing mkvs.
hello @lake1988! i have the same problem. the 'audio format is not supported' when i try to play bluray rip mkv format. i tried the muxer but the audio jus aint working. please help.
And here is the media properties:
General
Complete name : K:\MOVIES\HD\Avatar ECE (2009) [1080p]\Avatar.mkv
Format : Matroska
File size : 7.94 GiB
Duration : 2h 41mn
Overall bit rate : 7 033 Kbps
Encoded date : UTC 2008-04-23 14:39:32
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 21 2009 13:21:42
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 41mn
Bit rate : 5 383 Kbps
Nominal bit rate : 5 525 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.244
Stream size : 6.07 GiB (76%)
Writing library : x264 core 93 r1542M 5b86182
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5525 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 41mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
