Sony ht iv 300
SELVARAJ
I'm new to this music world.
I'm having SAMSUNG EH6030, SONY HT IV 300 & SAMSUNG BD F5500.
I would like to protect these from power fluctuations.
Can answer me the following questions?
1. Which stabilizer would be best?
2. Can I use single stabilizer for all above simultaneously?
Thanks in advance.
There are various brands of stabilizers available in the market and some have the facility to connect multiple devices...all depends on the power consumption value and load factor...please check carefully the power consumption of each device and then conduct a google search for possible answers which will help you to take the appropriate decision and make the correct purchase.
Thanks in advance.
V-guard digi 200 is the best in my view point. It is 6 amp stabilizer. Can connect all your audio video requirements.
Note- 200-230v level input time, stabilizer voltage also same.
Eb8NST
Eb8NST
I checked this with a few showroom and all of them told that Digi 200 is not required for this kind of setup (which can be used for fridge). Crystal Plus is the optimal solution.
