Sony W80D '55 or Lg 55LF6300
Samudragupta
mumbai
Hi friends i am currently in a dilemma. I am gettings a tv for my living room and the distance of viewing will be approx 15 feet. I have shortlisted Sony W80D '55 and Lg 55LF6300.
Im getting the sony after discounts for 1,13,000 and LG for around 92,000.
SOny is giving amc for rs 12,500 for 2 yrs but not sure about LG yet.
Is it worth getting the sony since when i asked the dealer he said honestly that if there are any issues with parts they take time to arrive. Sony display was really gorgeous comapred to the LG but is it worth the extra 20k?
I also want 43 inch TV for my bedroom so should i look at the same models listed above?
Please suggest friends. Thanks in advance
I have sony 50w800c model. I am still enjoying with it. The picture quality is way better than other televisions with this price range. The active 3D is outstanding and you have lot of streaming apps and comes with android OS.
I hope the D series should have better PQ than C series.
I have the 55W800D. I went with this cos it has better refresh rates. 100Hz I believe. 3D tv usually has better refresh rates.
I suggest that you Check out moving fast moving sceanes on both and decide.
I was able to see artifacts on the Sony coming from superior panny plasma. I found this sony to be better than others in this range that i explored. I don't recommend tv with 50Hz refresh rate. The bigger the panel gets easier to notice artifacts
