Sony's BDP-S370- Usb play capabilities- Discussion
partymonger
india
Ok so it seems that this player is capable of flawless mkv playback..:yahoo:
Does any one have the player and check it out thoroughly.?
1) Does it support ntfs? or any other file system not limited by file size (atleast till 20gb:) )
2) Does it decode rips with dts-hd ma and dolby true HD?
3) Can it decode dts hd ma and dolby true Hd, and output it via the optical port? Will such high bitrate out put be decoded by Phillips and lg HTIB's?
4) Is the mkv playback hassle free?
5) Is there a way to make the player's bluray region free?
6) How goos is its internet compatibility, like playing youtube videos etc?
7) how is the picture quality of the mkv playback?
8) Does it play the bluray files its m2ts via usb?
I've seen the player in action for blueray disk playback but not for mkv..
Please do discuss the above points,
If it does all the above flawlessly, its the next best thing after wdtv :yahoo:
EDIT:- Whatever files you test it with
1) mention the size of the file, file type, and display resolution, audio type and audio video bitrate..
2) And open in kmplayer and see the media info and paste it here in a quote tag.. Will help a lot.. Thanks!!
I went with the sample of the 1080p nhanc3 rip of transformers and it worked flawlessly..no issues..
Then came Hurt Locker..2.79gb rip, again flawless..
Just needed to plugin the pendrive and select usb..
it fastforword and rewind worked easily..
The fat32 file size limit is a PITA :@
Yep the FAT32 limit is PITA even in cameras where one can't record a continuous video clip for more then 4gb .
Can you share the video bitrate and exact resolution for these files.....
WMV Files - Plays perfectly if the WMA soundtrack consists of two channels. DOES NOT play the audio if the WMA track is of 6 (5.1) channels.
Does not play the video portion of some HD files with the .MP4 extension.
I have a 1080P Pirates Of The Caribbean trailer that produced only sound when played. Details of the file are as follows:
Complete name : G:\Pirates of the Caribbean - Dead Man's Chest - 1080p Trailer.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 124 MiB
Duration : 2mn 6s
Overall bit rate : 8 181 Kbps
Encoded date : UTC 2006-06-02 05:59:50
Tagged date : UTC 2006-06-02 05:59:50
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2mn 6s
Bit rate mode : Variable
Bit rate : 7 810 Kbps
Maximum bit rate : 16.6 Mbps
Width : 1 920 pixels
Height : 796 pixels
Display aspect ratio : 2.412
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.213
Stream size : 118 MiB (96%)
Title : Video
Writing library : x264 core 46 svn-516
Encoding settings : cabac=1 / ref=3 / deblock=1:-4:-3 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=1 / nr=0 / decimate=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=7810 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Encoded date : UTC 2006-06-01 13:26:01
Tagged date : UTC 2006-06-02 06:00:06
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : 40
Duration : 2mn 6s
Bit rate : 48.0 Kbps
Maximum bit rate : 52.8 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 736 KiB (1%)
Language : English
Encoded date : UTC 2006-06-02 06:00:05
Audio #2
Format : AAC
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 2mn 6s
Bit rate : 316 Kbps
Maximum bit rate : 367 Kbps
Sampling rate : 44.1 KHz
Stream size : 4.77 MiB (4%)
Language : English
1) Does it support ntfs? or any other file system not limited by file size (atleast till 20gb:) ) --- WIll check this weekend.. unlikely from the USB. from the network -- will require a firmware upgrade said to be fcoming july
2) Does it decode rips with dts-hd ma and dolby true HD? Mkv - t-HD yes
3) Can it decode dts hd ma and dolby true Hd, and output it via the optical port? Will such high bitrate out put be decoded by Phillips and lg HTIB's? -- yes - the core stream is output - spdif specs do not allow a bitrate of more than 1.5Mbps
4) Is the mkv playback hassle free? - in my limited experience, yes - challenge to get it off the network still
5) Is there a way to make the player's bluray region free? not known yet - if youd find any way - do post
6) How goos is its internet compatibility, like playing youtube videos etc? - average - but firmware upgrades have been promised
7) how is the picture quality of the mkv playback? - from USB - it's okay - but i got the (highly subjective) feeling that BD quality is better - but need to do an a/b to confirm
8) Does it play the bluray files its m2ts via usb? - said to, not checked.. figured if it plays mkvs, it definitely play these.
If it does all the above flawlessly, its the next best thing after wdtv :yahoo: --- it's not - for getting stuff off the network it's currently nowhere in the same league. if the promised firmware upgrade gives the functionality, it'll still be unlikely to have the bells and whistles of NMT.
hi - i have given the replies within your quotes itself. my belief is that once (and if) the promised upgrade delivers full network functionality, it could be substitute, but I doubt it will ever have the visual slickness of an HTPC interface (mymovies etc) or a good NMT interface.
This file not playing is no surprise, the format profile is [email protected], did you try playing the same file in any of the media player????. Ok find a file with Profile [email protected] or lesser and same reference frame....and try again and report .....
D:\Tor\Transformers ROTF IMAX 1080p BluRay xnHD x264 NhaNc3\T-Sample.mkv
General
Complete name : D:\Tor\Transformers ROTF IMAX 1080p BluRay xnHD x264 NhaNc3\T-Sample.mkv
Format : Matroska
File size : 81.3 MiB
Duration : 1mn 1s
Overall bit rate : 11.1 Mbps
Encoded date : UTC 2009-10-24 23:42:07
Writing application : mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #1
Format : AVC
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 1s
Height : 1 080 pixels
Display aspect ratio : 16:9
Colorimetry : 4:2:0
Language : English
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1mn 1s
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Language : English
Text #3
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Here you go..the details are in the qoute, from km player..
Its high at 4.1:licklips:
This is the main file which i didnt take, but the previous file is a sample from this.
D:\Tor\Transformers ROTF IMAX 1080p BluRay xnHD x264 NhaNc3\Transformers ROTF IMAX Edition 1080p BluRay xnHD x264 NhaNc3.mkv
General
Complete name : D:\Tor\Transformers ROTF IMAX 1080p BluRay xnHD x264 NhaNc3\Transformers ROTF IMAX Edition 1080p BluRay xnHD x264 NhaNc3.mkv
Format : Matroska
File size : 4.38 GiB
Duration : 2h 30mn
Overall bit rate : 4 169 Kbps
Encoded date : UTC 2009-10-24 23:43:40
Video #1
Format : AVC
Duration : 2h 30mn
Nominal bit rate : 3 842 Kbps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.077
Writing library : x264 core 75 r1247 b3efbe5
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=4 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3842 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 2h 30mn
Language : English
Text #3
Format : UTF-8
Language : English
Strange the sample has a different specifications than the original, Also the bitrate for video is missing for the sample file (not the overall bitrate but video). Also there is no Audio bitrate for both the files ....
Can you use media info to get the details .... media info is more accurate and detailed in these matters
General
Count : 267
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : Matroska: 81.3 MiB, 1mn 1s
Count of video streams : 1
Count of audio streams : 1
Count of text streams : 1
Count of menu streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Video_Language_List : English
Audio_Format_List : AAC
Audio_Format_WithHint_List : AAC
Audio codecs : AAC LC
Audio_Language_List : English
Text_Format_List : UTF-8
Text_Format_WithHint_List : UTF-8
Text codecs : UTF-8
Text_Language_List : English
Folder name : D:\Tor\Transformers ROTF IMAX 1080p BluRay xnHD x264 NhaNc3
File name : T-Sample
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : CCCP - Combined Community Codec Pack
Format/Extensions usually used : mkv mka mks
Format_Commercial : Matroska
Codec : Matroska
Codec : Matroska
Codec/Url : CCCP - Combined Community Codec Pack
Codec/Extensions usually used : mkv mka mks
File size : 85253866
File size : 81 MiB
File size : 81 MiB
File size : 81.30 MiB
Duration : 61568
Duration : 1mn 1s
Duration : 1mn 1s 568ms
Duration : 1mn 1s
Duration : 00:01:01.568
Overall bit rate : 11077685
File creation date : UTC 2010-06-11 23:02:19.293
File creation date (local) : 2010-06-12 04:32:19.293
File last modification date : UTC 2010-06-12 01:09:24.382
File last modification date (loc : 2010-06-12 06:39:24.382
Video
Count : 177
Kind of stream : Video
Inform : English, 1920*1080 (16:9), at 23.976 fps, AVC (Container [email protected]) ([email protected]) (CABAC / 5 Ref Frames)
UniqueID : 1
Format : AVC
Format/Url : VideoLAN - VideoLAN - x264
Format_Commercial : AVC
Format settings : CABAC / 5 Ref Frames
InternetMediaType : video/H264
Codec ID/Url : ffdshow tryouts | Official Website
Codec : V_MPEG4/ISO/AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : ffdshow tryouts | Official Website
Codec profile : [email protected]
Codec settings : CABAC / 5 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 5
Duration : 61562
Duration : 1mn 1s
Duration : 1mn 1s 562ms
Duration : 1mn 1s
Duration : 00:01:01.562
Width : 1920
Height : 1080
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Frame rate : 23.976
Frame count : 1476
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Interlacement : Progressive
Delay : 0
Delay : 00:00:00.000
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Audio
Count : 140
Kind of stream : Audio
Inform : English, 48.0 KHz, 6 channels, AAC (Version 4) (LC)
UniqueID : 90338974
Format : AAC
Format_Commercial : AAC
Format profile : LC
Codec ID : A_AAC
Codec : A_AAC/MPEG4/LC
Codec : AAC LC
Codec/Family : AAC
Codec/Info : AAC Low Complexity
Duration : 61568
Duration : 1mn 1s
Duration : 1mn 1s
Channel(s) : 6
Channel positions : Front: L C R, Side: L R, LFE
Channel positions : 3/2/0.1
Sampling rate : 48000
SamplingCount : 2955264
Delay : 0
Video delay : 0
Video0 delay : 0
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Text
Count : 119
Kind of stream : Text
Inform : English, UTF-8
UniqueID : 4237350066
Format : UTF-8
Format_Commercial : UTF-8
Codec : S_TEXT/UTF8
Codec : UTF-8
Codec/Info : UTF-8 Plain Text
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Menu
Count : 66
Kind of stream : Menu
Chapters_Pos_Begin : 65
Chapters_Pos_End : 66
00:00:00.000 : en:00:00:00.054
Here you go...seems like the same info to me..
So in the Sony S370, if I am playing a MKV file from a HDD connected to the USB, what will be outputed on the Optical (the original audio stream which may be compressed DTS, DD or lossless DTS-MA, DD-THD as the case maybe) or decoded into 7.1, 5.1 LPCM ? Basically I am trying to figure out if the Sony BDP will do the audio processing or it will do a passthru of the audio and let the AVR do it.
similarly what sort of Audion stream will go in the HDMI output in this case (i.e. playing MKV file with DTS,DD, or HD DTS, DD track)
thanks for the info
^Thats precisely wat i want to find out, if it does, its the cheapest decoder available for hd sound \m/
Only someone who has the player can experiment so much and tell, not possible at a shop...:(
thanks for the info
Weather the player, decodes or does passthrough can be found out in the player settings itself. I think this one does decodes. Also if its optical we are using the player cannot pass DTA MA or DD-THD. Optical cannot do HD audio.
hi sam9s
That helps.. so I can hook up Optical to a AVR but it would work in case of older Audio formats (ie non lossless). If I want to enjoy Blueray/MKV with the newer, lossless audio encoded, then I can do it only thru a HDMI connection carrying audio+video between BDP and AVR... and also in that case the AVR needs to support HDMI Repeater mode...
So a long termish investment strategy would imply buying a HTiB which has a HDMI Repeater AVR...
I seem to be settling for the Onkyo HTS3300.... the thing is not very commonly available in India though.. might just be worthwhile buying it in US thru online stores and getting it over to india.. apparently for items < 25K INR theres no customs...
If you want to buy Onkyo 3300 in NCR, please PM me, I know someone who has the stock and you can buy even today. :)
thanks for the info
Unfortunately Sony S370 not support HDD (i bought for HDD support but) , only pendrive (8GB) or u have to burn MKV or AVi files on DVD (support DVD9 to) .
REGARDS
REGARDS
Did you format it to fat 32 or ntfs?
Try with fat 32, and when u plug it in, give it some time..
send me a list of what you want checked by pm or post here, and I'll try to check the rest of the week.
Has anyone tried playing back the HD version of the Big Buck Bunny movie? I've tried a 1080P version that the Sony wouldn't play:
Complete name : D:\Movie Files\HD Files\HD\big_buck_bunny_1080p_surround.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 886 MiB
Duration : 9mn 56s
Overall bit rate : 12.5 Mbps
Writing application : AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : FMP4
Duration : 9mn 56s
Bit rate : 12.0 Mbps
Display aspect ratio : 16/9
Frame rate : 24.000 fps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.241
Stream size : 853 MiB (96%)
Writing library : Lavc51.44.0
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 9mn 56s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 31.9 MiB (4%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.54 video frames)
Interleave, preload duration : 192 ms
BBB is available for download here: Big Buck Bunny Download
